VR 控制台命令和变量
After VR initialization, a set of VR-related console commands will become available.VR初始化后,一组与VR相关的控制台命令将可用。
Common VR Settings常见 VR 设置#
描述:
描述:
配置文件: | |
描述:
| 参数: 0 - 关 (默认) 1 - 开 |
配置文件: | |
描述:
| 参数: 0 - 关 1 - 开 (默认) |
配置文件: | |
描述:
| 参数: [0; 200] - 可用范围 60 - 默认 |
配置文件: | |
描述:
| 参数: 0 - black screen (no image is displayed). 1 - image rendered for the left eye. 2 - image rendered for the right eye. 3 - stereo image (both the left and right eyes). (默认) |
配置文件: | |
描述:
| 参数: 0 - mirroring is disabled. 1 - main window displays the mirrored image. (默认) |
配置文件: | |
描述:
| 参数: 0 - seated. 1 - standing. (默认) 2 - raw (uncalibrated). |
配置文件: | |
描述:
配置文件: | |
描述:
配置文件: | |
描述:
配置文件: | |
描述:
| 参数: [eps; inf] - 可用范围 32.0f - 默认 |
配置文件: | |
描述:
| 参数: [eps; inf] - 可用范围 1.0f / 60.0f - 默认 |
配置文件: | |
描述:
Mixed Reality Settings混合现实(MR)参数#
描述:
描述:
描述:
描述:
描述:
描述:
| 参数: vec2(0.0f, 1.0f) - default value |
描述: exposure time value that is valid for the connected device. | |
描述:
| 参数: 0 - exposure adjustment is disabled 1 - automatic exposure adjustment (默认) 2 - manual exposure adjustment |
描述: ISO value for the camera.white balance correction value that is valid for the connected device. | |
描述:
| 参数: 0 - white balance adjustment is disabled 1 - automatic white balance adjustment (默认) 2 - manual white balance adjustment |
描述: ISO value for the camera. | |
描述:
| 参数: 0 - ISO adjustment is disabled 1 - automatic ISO adjustment (默认) 2 - manual ISO adjustment |
描述: flicker compensation value for the camera. This is useful when using the HMD indoors with mostly artificial light bulbs, which flicker at the frequency of 50Hz or 60Hz and can cause visual flicker artifacts on the video see through image. The correct setting depends on the underlying power grid's frequency. For example, in most parts of Africa/Asia/Australia/Europe the frequency is 50 Hz and in most parts of North and South America 60 Hz. | |
描述:
| 参数: [0; 10] - 可用范围 0 - 默认 |
描述:
| 参数: [0.0; 1.0] - 可用范围 0.0 - 默认 |
描述:
配置文件: | |
描述:
描述:
| 参数: 0 - Disabled (masking mode is disabled). (默认) 1 - Restrict Video to Mask (show the video pass-through image (VST) in the mask; can be used with chroma key) 2 - Restrict VR to Mask (show VR in the mask; can be used with chroma key) 3 - Restrict VR to Chromakey reduced by Mask (show VR in the mask and chroma elsewhere; requires chroma key) |
描述:
描述:
| 参数: 0 - cubemap streaming from AR cameras is disabled. 1 - environment texture substitutes the sky. 2 - the first environment preset defines the way the AR texture is set for the environment. (默认) 3 - the second environment preset defines the way the AR texture is set for the environment. 4 - the third environment preset defines the way the AR texture is set for the environment. |
描述:
| 参数: 0 - low 1 - medium (默认) 2 - high 3 - ultra |
描述:
| 参数: 0 - correction is disabled. (默认) 1 - exposure correction for the stream from the AR cameras. 2 - exposure and white balance correction for the stream. |
最新更新:
2024-02-27
