Copying User Files
Sometimes you may want to add some files stored outside your project to the build (e.g. end-user agreement, etc.). User files are added to the build folder by filling in the following table:
- From (Absolute Path) — an absolute path to a source file or folder. Folders can be specified using wildcards.
- To (Relative Path) — path to the destination folder that is relative of the Build Folder. It can be a name of the folder into which the file or files are copied, or folder name + file name (if you need to rename the copied file).
