World Trigger
World Trigger is a cuboid shaped node that triggers events when any node (physical or not) gets inside or outside it. World Trigger can detect a node of any type by its bound and can be used to access node's components and parameters.
World Triggers detect only the nodes with Triggers Interaction enabled - either in the Editor or via API.
The following "abstract" nodes do not have bounds; therefore, they do not interact with World Trigger (regardless of the Triggers Interaction option state):
- Dummy Node
- Node Reference
- Node Layer
- World Switcher
- World Transform Path
- World Transform Bone
- World Expression
- Dummy Object (if it has no body assigned)
- WorldTrigger class to manage World Trigger via API
A set of samples located in the data/samples/worlds folder:
- trigger_01
- trigger_02
- Videotutorial on How To Use World Triggers to Detect Nodes by Their Bounds
Creating a World Trigger#
To create World Trigger via UnigineEditor:
On the Menu bar, choose Create -> Logic -> World Trigger.
- Place the node in the scene.
Editing a World Trigger#
In the Node tab of the Parameters window, you can adjust the following parameters of World Trigger:
Bounding Box Parameters#
Edit Size |
Toggles the editing mode for the World Trigger node on and off. When enabled, the bounding box sides that can be resized are highlighted with the colored rectangles. To change the size of a side, drag the corresponding rectangle. |
Touch | Toggles the touch mode for World Trigger on and off. With this mode on, World Trigger reacts to the node at a partial contact. Otherwise, World Trigger reacts only if the whole bounding box gets inside it. |
Size | The size of the World Trigger bounding box along the X, Y, and Z axes, in units. |
Handling Events#
To perform specific actions when a node enters or leaves the World Trigger, you should implement event handlers that receive a Node as the first argument. Then, you should subscribe to the Enter and/or Leave events and call connect().
// subscribe to the Enter event when a node enters the world trigger with your handler
worldTrigger->getEventEnter().connect(enter_event_handler);
// subscribe to the Leave event when a node leaves the world trigger with your handler
worldTrigger->getEventLeave().connect(leave_event_handler);
worldTrigger.EventEnter.Connect(enter_event_handler);
worldTrigger.EventLeave.Connect(leave_event_handler);
