启动器配置
In addition to building the project, Build Tool allows you to automatically generate a Launcher for it. You may have already encountered launchers: before launching the game itself, an application with a picturesque splash screen opens, allowing you to set the necessary settings (VR mode, resolution, additional launch arguments, etc.). You can automatically generate a bat/sh script, or you can create a GUI-based launcher:除了构建项目外,Build工具还允许你自动生成项目启动器(Launcher)。你可能已经接触过这类启动器:在启动游戏本体前,会先打开一个带有精美启动画面的应用程序,允许你设置必要的参数(VR模式、分辨率、额外启动参数等)。你可以选择自动生成bat/sh脚本,也可以创建基于图形界面的((GUI-based))启动器:
To customize the launcher, select the GUI-Based type in the Launcher Default Settings group.要自定义启动器,请在Launcher Default Settings(启动器默认设置)组中选择GUI-Based(基于图形界面)类型。
