API Samples
API Migration
Major Changes#
Breaking Changes#
CustomSystemProxy Class#
Dir Class#
FileSystem Class#
FileSystemMount Class#
GeodeticPivot Class#
InputGamePad Class#
New Functions
InputJoystick Class#
Json Class#
New Functions
Landscape Class#
UNIGINE 2.19.1 UNIGINE 2.20
getTemporaryTexture( const Math::ivec2 & ) Removed. Landscape textures should now be created using the corresponding constructor LandscapeTextures::create( const Math::ivec2 & ).
releaseTemporaryTexture( const Ptr<LandscapeTextures> & ) Removed. Landscape textures are now removed via the destructor of the LandscapeTextures class.
New Functions
LandscapeMapFileSettings Class#
Light Class#
LightEnvironmentProbe Class#
LightVoxelProbe Class#
setAmbientCubicFiltering( bool ) Renamed as setDiffuseCubicFiltering( bool ).
isAmbientCubicFiltering( ) Renamed as isDiffuseCubicFiltering( ).
setAmbientBias( float ) Renamed as setDiffuseNormalBias( float ).
getAmbientBias( ) Renamed as getDiffuseNormalBias( ).
setReflectionEnabled( bool ) Renamed as setSpecularEnabled( bool ).
isReflectionEnabled( ) Renamed as isSpecularEnabled( ).
setReflectionBias( float ) Renamed as setSpecularReflectionBias( float ).
getReflectionBias( ) Renamed as getSpecularReflectionBias( ).
setReflectionCubicFiltering( bool ) Renamed as setSpecularCubicFiltering( bool ).
isReflectionCubicFiltering( ) Renamed as isSpecularCubicFiltering( ).
setReflectionVisibilityRoughnessMin( float ) Renamed as getSpecularVisibilityRoughnessMin( float ).
getReflectionVisibilityRoughnessMin( ) Renamed as getSpecularVisibilityRoughnessMin( ).
setReflectionVisibilityRoughnessMax( float ) Renamed as getSpecularVisibilityRoughnessMax( float ).
getReflectionVisibilityRoughnessMax( ) Renamed as getSpecularVisibilityRoughnessMax( ).
New Functions
Material Class#
Mesh Class#
ObjectLandscapeTerrain Class#
ObjectMeshSkinned Class#
getBoneSkiningTransform( int ) Renamed as getBoneSkinningTransform( int ).
PackageUng Class#
PackageUng( const char *, const char * ) Set of arguments changed.
clone( ) Removed.
getCompressionType( ) Removed. Use getCompressExtension( int ) instead.
getFileName( int ) Removed. Use getFilePath( int ) instead.
removeFile( const char * ) Removed.
removeFile( int ) Removed.
New Functions
Property Class#
PropertyParameter Class#
Render Class#
RenderState Class#
RenderTarget Class#
Profiler Class#
Shader Class#
getD3D11ComputeShader( ) Removed.
getD3D11ControlShader( ) Removed.
getD3D11EvaluateShader( ) Removed.
getD3D11FragmentShader( ) Removed.
getD3D11GeometryShader( ) Removed.
getD3D11VertexShader( ) Removed.
StructuredBuffer Class#
getD3D11ShaderResourceView( ) Removed.
getD3D11UnorderedAccessView( ) Removed.
isUsageCPUResource( ) Removed. Use isUsageRender( ) instead.
isUsageGPUResource( ) Removed. Use isUsageRender( ) instead.
New Functions
Texture Class#
Unsupported texture formats (RGB8/RGB16/RGB32, R24B8, D24) were removed, see replacement details below.
create( const Ptr<Image> &, int, int, int ) Set of arguments changed.
getD3D11DepthStencilView( ) Removed.
getD3D11DepthStencilView( int ) Removed.
getD3D11RenderTargetView( int ) Removed.
getD3D11RenderTargetView( ) Removed.
getD3D11Texture( ) Removed.
getD3D11UnorderedAccessView( int ) Removed.
fromD3D11Texture2D( void *, int, int, int, int, int ) Removed.
fromD3D11Texture2D( void *, int, int, int, int ) Removed.
FORMAT_RGB8 Removed. Use FORMAT_RGBA8 instead.
FORMAT_RGB16 Removed. Use FORMAT_RGBA16 instead.
FORMAT_RGB16U Removed. Use FORMAT_RGBA16U instead.
FORMAT_RGB16F Removed. Use FORMAT_RGBA16F instead.
FORMAT_RGB32U Removed. Use FORMAT_RGBA32U instead.
FORMAT_RGB32F Removed. Use FORMAT_RGBA32F instead.
FORMAT_R24B8 Removed. Use FORMAT_R32F instead.
FORMAT_D24 Removed. Use FORMAT_D32F instead (in case the Stencil was used, replace with FORMAT_D24S8/FORMAT_D32FS8).
VR Class#
VREyeTracking Class#
VRHand Class#
isActive( ) Renamed as isTracking( ).
VRHandTracking Class#
New Functions
VRMixedReality Class#
Viewport Class#
setPaused( bool ) Removed.
isPaused( ) Removed.
New Functions
ViewportData Class#
Visualizer Class#
Widget Class#
WidgetTreeBox Class#
WidgetVBox Class#
IG::Manager Class#
IG::Entity Class#
Last update: 09.06.2025
